TwinTurbo.NET: Nissan 300ZX forum - probably not your thermostat
aliaZ
on June 16, 2008 at 12:37 PM
it did smoke a bit but when i pulled over from the back of t
posted by pearlyellowtt
on June 16, 2008 at 12:26 PM
You need to find the source of your leak. Check your water pump and hoses.
not such a good day so far!!!
pearlyellowtt
11:48:57 06/16/08
maybe you should try a different brand of R134a?
aliaZ
12:04:31 06/16/08
pearlyellowtt
12:26:06 06/16/08
probably not your thermostat -
aliaZ
12:37:49 06/16/08
there is a small leak on the drivers side of the engine that
pearlyellowtt
13:37:08 06/16/08
found it!!!!! the coolant hose that runs to the drivers side
pearlyellowtt
16:03:21 06/16/08
glad you found the problem
aliaZ
17:04:35 06/16/08
oh, in addition, i did have a small belt squeel this morning
pearlyellowtt
12:27:18 06/16/08
check your water pump
aliaZ
12:39:11 06/16/08
I have the same issue (no heat)...
cherryz
15:02:06 06/16/08
